OK, but how does he know this is where the leak is? when i do a pressure/vac test i slacken the carb screws, place a rubber wedge between the carb and inlet boot, re tighten the carb screws.
Good point well made Andrew . :001_smile:
  • Replies 28
The boot may be split and you cant see it untill you pull it and stretch it this wasy and that . Try a new boot .
Put a new boot on, didnt help. It was first thing i tried. :001_smile:
Just a question, how do you know its leaking?
When its assembled and running, which is difficult to keep running, i carefully spray a bit of cleaner at the joint and the saw revs its nuts off.:001_smile:
Thought it was the carb at fault? Least it was that you were blaming last week! :001_tt2::lol::lol:
Carb replacement was needed to discount that as the issue, gaskets were very poor, carb full of bits and h n l screws looked like someone has driven them in with a sledge hammer. For the price of the carb it wasnt worth not replacing to make the saw good again, or at least try to. :001_tt2:
Not doing pressure test just testing with spray around the joints.:001_smile:
