You can use it long term, no problem. Have been using it exclusively for several years, never any problem. Keep the saws and containers away from mice and rats though....I would suggest if you're going to convert to rapeseed that you flush out the chain oil tanks with white spirits or old petrol first to remove all traces of mineral oil. I don't know if this is actually necessary, but I would imagine that mineral and organic won't mix, and therefore there might be a film of mineral on the tubes, which might possible become a problem down the road....I really don't know, just went with my gut and haven't have any issues.
sound advice, much appreciated, will give the saws a flush out in the morning.:thumbup:
  • Replies 23
careful rats/mice dont eat through the oil tank which is what happened to me
And me on the pole pruner, good old araldite and a bit of glass fibre fixed it, but best to flush the tanks out and put mineral oil if you're going to leave them till next season.
I tried mixing rapeseed oil with mineral oil. It turned into gel. The saw oiled fine with the gel, but I wouldn't recommend mixing them.
Don't forget to turn up the oil flow to max if you haven't already. Rapeseed oil is thinner than conventional chain oil. It is also cheaper to buy, can be stored over time, and it's better for the environment.
