Do the outer felling spikes fit on the bar bolts ? You should be able to make any fit if you have a drill and a bit of ability.
No . there are two recessed holes in the clutch cover for captive nuts I seem t remember .
Stubby is correct inner 562 will fit 560 but not outer. You drill the cover and bolt though to fit but the 562 cover is different to 560 slightly due to the larger bar pad hence the spacing is different.
There is a Jonsered part No for some that fit the 560 inner and outer . maybe they do one for the 550 but I dont know .
