I've tried them, but can generally find most hinge substantially cheaper than here offerings, struggling a bit with this though
That's true of most OEM parts fitted by a manufacturer, the trick is to identify the original manufacturer and model. Sometimes a manufacturer will have a slightly non standard part modified for their use and the OEM part is only supplied through the manufacturer, like the brevini feed motors on a greemech, but other OEM parts do fit.
The original Doskos which where copied had no clutch and the wheel ran continuously, the electro magnetic clutch was a a retrofit for the Kohler engine, similar clutches are used on the vermeer stump grinders and Toro mowers but they all seem to cost about 300 quid.
We bought one from Flowfit in Ludlow for a Vermeer at a good price. Their supplier is based in N Wales. Either Colwyn or Rhyl. Can't remember which and I'm pretty sure you can go direct to them. If I remember their name I'll post it up.
