Gerbutt
Helmet radio ear defenders.
Hiya
Which are a good pair of radio ear defenders that clip on to helmets? I've heard the peltor ones have real bad reception?
Thanks for any input.
Share this post
Link to post
I use the husqvarna ones in rural Northumberland and I get good reception :-)
Sent from my D6603 using Arbtalk mobile app
Thanks for that. Do you find the defenders themselves acceptable?
Share this post
Link to post
Yes, as comfortable as normal ear defenders, only used with a chainsaw so not sure how good they are if used with a chipper etc, they're simple to use with gloves on, one button for the 4 volume levels, hold it in to switch on/off, two other buttons to cycle through fm to find channels
Share this post
Link to post
If you can find a set of the old style husky ones, (they do still surface from time to time) then they are leagues ahead of the newer style ones. I didn't get on with the new ones at all - they were a lot heavier and would swing on the hangers if they were just popped off your ears and they didn't seal to my head as well as the old ones either. As a radio though, they did work well enough.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
