An update on the alternative to Honda situation - don't buy Chinese, at least not the Evo420, it didn't last 2 months. I hope that yours is doing a bit better Redmoosefaction.
I've had a Subaru engine on the machine for a few months now and can recommend these.
Sent from my iPad using Arbtalk
if you bought honda you would only had to buy once :biggrin:
  • Replies 25
:) true, at least for a few years.
The Subaru is good quality and should last. The cost of both engines still come in less than one Honda but what I have learnt is that the down time of frequently replacing the crap engines should be factored into the decision of which engine.
what failed on it
what failed on it
It started doing the same as the old Honda engine - lack of power, smoking, back firing, then it wouldn't start at all.
The trouble with these engines strapped to pedestrian grinders is that they often work at extreme angles. I made sure that the engine oil was always topped up but i guess that these cheaper engines are much less tolerable to working like this than a Honda or equivalent.
Yea splash lube is no good if you are at angles . Got to be a pressure fed system . Honda or otherwise .
did you try to adjust the valve clearances before you condemned it this sounds like an easy fix I've had genuine Hondas that have done the same ours blew the guts out the carb a quick adjustment and a new carb and it was fine
