Split a stack of ash today, put it in a separate pile in the barn. What do you reckon, 6 months then it's good enough to sell without any comeback, or do you guys season longer?
Is ash not good to go straight away?
No. You often hear people say ash will burn green but I would add only if you have to. IIRC, felled when it's dormant, it'll have a moisture content between 30 - 45%, less than many other woods but some stove manufactures state 20%, some higher, so it will need some seasoning. How much would depend on a number of factors.
No, fresh cut in winter it has a MC of about 35%, that will burn but not well. It will give poor heat and be depositing excess soot and tar into the flue.
If it was felled last winter I doubt it will be ready by Sept but might be OK by January.
A
