tool box is handy, roof is esential i think with a rear mounted chipper. keep it within the width of the mog mirrors for sure. top hinges like cylage back doors. i have a removable stainless roof that was on my 2150 if thats any use.
That looks great Garth!!
I've not seen 2 point linkage before, does it work OK??
its not too bad once u get used to the motorists flashing their lights at you because the chipper is dragging along the deck!:001_smile:
Yeah Atkinsons bodies are ok, you will need to budget getting it properly sprayed. What they send them out in is cack.
all of the stuff for my mog i generally get blasted first then galvanised and sprayed. i do alot of work for a steel yard who have in house facilities and do the work at a reduced rate in exchange for work i do for them
