Cheers fella, makes perfect sense👍
Didn't think about opening the hopper🙄
No problem I've strapped my cs100 down like that the past two years and never had a problem. Just remember to run the strap inside the hopper or you might break the emergency stop button
On my trailer the ramp tailgate is about the same height as the feed hopper. I use a strap with the ratchet on one end and then just a long strap that makes a big loop that you can tighten... Hopefully you can picture what I mean? It doesn't need hooks and just feeds back through it's own buckle. I run that through the bottom of the ramp, over the axle by the wheel and then under the machine and back over the axle by the other wheel. I then run it back out and up the outside of the tailgate, back in at the top and around the hopper in a similar manner. Tighten that up and it's rock solid. No straps needed on the front. It sounds long winded but takes maybe a minute to do
For me a similar issue was solved by replacing the strap down belts.
For some reason they never stopped lengthening a few mm.
Went with those retractable ratchets and never looked back. A big time saver too.
Regards
