We are bringing in the first batch of these and offering a discount to the first ten customers who pre-order. Delivery in July. Please get in touch if you are interested:
The Eder Powerwinch 1800 is our most powerful capstan winch - great for assisted felling, dealing with hung up trees and extracting timber.
RRP: £1640.00 + VAT
01824 538 638
07970 544 901
[email protected]
The Eder Powerwinch 1800 is manufactured in Germany.
The Eder Powerwinch 1800 is characterised by its lightness and great strength.
It has a max rated capacity of 1800kg making it the most powerful portable capstan winch we sell.
In any position, it is capable of pulling an object that is 125 times its own weight.
Advantages:
62cc 2 stroke engine – Can run in any position including upside down. Uses the same 2-stroke mix as your chainsaw.
2 gears –
1st gear: 1800 kg pull at 12 m / min
2nd gear: 900 kg pull at 24 m / min
Centrifugal clutch – Capstan drum does not rotate at idle.
Automatic brake – stop pulling on the rope and the load is automatically held.
Automatic throttle – As you pull on the rope the throttle is automatically engaged.
Weight – weighs only 14kg.
[ame]
[/ame] Edited by Treadlight Forestry
So this deal is shaping up nicely.
The first batch of ten winches will be on a special offer price of £1450 + VAT + delivery each. (RRP is £1640 + VAT)
Four winches have already been pre-ordered leaving six remaining.
Delivery will be in July.
Please get in touch if you are interested.
  • 4 years later...
This deal still available I wonder?
Sorry - that deal was a one off and 4 years ago!
Drop me an email with what you need in terms of winch and accessories and I will sort the best deal I can:
[email protected]
TREADLIGHTFORESTRY.CO.UK
The EDER 1800 portable capstan winch is all about power! With a 1800kg straight line pull it is the most powerful portable capstan winch of this type on the UK market.
I bought one from tread light this year. Epic bit of kit. I bought it for one job but have ended up using it quite a lot. It’s a good bit of kit to have in the shed.
I've been thinking about these winches rather than going for winch bumper on the Defender.
Seems like it would be much more versatile and not that much more expensive by the time you've put a new bumper and bought a decent winch.
