  • Replies 20
Don't forget though Paul, you need unapproved hackers like me doing rapey tree work to make the approved guys look better!
Probably the most wise thing you've said, just here to make others look good. Cheers Mark🖒
I'm wrecking my brain here to try to say something "smart n witty" n to your exacting standards Mark...but I'm struggling :confused1::biggrin:
Cheers..
Paul
PS n we all know that isn't the case at all...what you've posted! :thumbup1:
Many a true word said in jest mate!
Seriously I normally get decent freelancers in for reductions.
I was never the best at them, and seem to have got worse.
Most of them ended up with a grind!
Nowt wrong with that, CR's were never my strong point either n I always relied on a good grounds-man n his pointy finger.
AND the Approved Contractor Scheme allows for this also :001_rolleyes: (bet Jake likes this one)
Av'a'gud'un..
Paul
I'm scaling things down these days Paul, but if I was on the way up I think AA approved status is a no-brainer.
I think most decent outfits probably don't realise that most of their ducks are already in a row.
"I'm interested to look closer"...get an ARB Approved Contractor application in quick :001_rolleyes:
It is a re-reduction though. Been done before. Nice though.
had that tree been reduced to those points before?
Yeh it had been hit really hard in the past and then been reduced again since then. Spec was back to previous, but I tried to give it a better shape as the house side had been hit harder than road side on the previous reduction. Also the top had been reduced harder than the lower half so I tried to balance it out a bit.
Thanks for the comments guys!
Paul I will pass your msg onto my boss 👍
