Bar type
Swampster
I used to use a 47" Duromatic on my mill (before that particular bar and powerhead were stolen). This was with an 076. I think it depends to an extent on the saw - more modern saws with higher revs suffer more as the chain passes faster so there is more friction and more heat build-up, whereas older saws with lower revs and more torque result in less heat build-up. That said, with the 076 I found it beneficial to add a bit of oil to the bar nose when the saw was resting in the cut and an auxiliary oiler would have been a good idea.
Alec
