Hi Y'all!
Can anyone tell me how to correctly tension my CS100 belts?
The manual gives a torque/force figure (in Newtons) but I'm not sure how to measure this. Is there a special tool that measures the tightness of the belt (by deflection?).
Don't want them to slip and neither do I want to screw up the bearings by having them too tight...
Thanks.
Hi Y'all!
Thanks.
Torque Wrench.
Hi Y'all!
Thanks.
Dayco do a Krikit gauge if you want to spend £30 ish Krikit? V-Belt Tension Gauge | Gates Corporation BSL or any decent belt supplier should be able to get one for you.
Bob
I tend to tighten them until with reasonable pressure with one finger, the belt can be pushed inwards to a depth of around 5mm or the depth of the other belt.
