Can anyone hazard an approximate guess to the weight of a builders bag of seasoned hardwood logs cut and split. I'm looking to downsize to a smaller van and wondering what the weight might be so not to overload a small van.
thanks
  woodsman said:
Thanks, im just looking at small vans with a 600kg payload as an alternative to deliveing logs.
Good plan, I reckon, especially if you find yourself delivering a single bag a lot of the time.
Worth noting that a lot of the smaller vans have pretty low trailer weights, if that's a consideration?
eg; A Peugeot Partner would be 1100kg Max gross trailer weight for a braked trailer and only 500kg Max for an unbraked trailer.
Although there is an 800kg payload version of the Peugeot Partner.... if you can fit two bags inside?
cheers, steve
Read more
