Jensen a530t creeping...
swinny
Im just wondering if anyone else has had this problem? On a banking the chipper will start to creep away over time. Also if on a hill and left in trailer and chipping it will start to creep back aswell (maybe partially vibrate back)
Is it spool valves going or what else can i check? I think and im hopin its something simple.
Cheers
The track motor has an internal brake. A leak will stop it working and as Johnny says an internal leak wont show hence the need to test
Ahh, i'll monitor which one is creeping then get it off at some point to be checked. Where would do this?
Also can the fuel tank be removed without removing the hopper? Cheers
