Hi Guys , recently got a 385 xp and have discovered the the clutch side cover is damaged , whoever had it previously repeatedly used excessive force to tighten the bar nuts or it got jammed in a big log or something which has cracked the casing and buckled it a bit which has over time worn the alloy away and the bar tensioner will only travel 2/3 of the way up due to the distortion , it still works ok but its irrititating me now , anyone have a decent casing they could sell me ? , its the same casing fitted to most of the bigger 3 series saws , 365/371/372/385 390 and the 570/575 , OEM part No is 537 00 40 with side adjuster
thanks for any input
Roy
Edited by huskywilson
hmm dunno , i took the one off my 2013 372 and it fits right on perfectly so i dont know what the differences are ? the part no i quoted is from the damaged cover , but it may be wrong as you say ,
I did search through the part numbers for the 385 xp and the number you quoted is indeed the correct one , but with the 372 xp cover on its fits pefectly and was no issue today with a full tank of Aspen through it blocking up some big pine , unless i can get a correct cover to see the difference, those covers i listed will do if anyone on here has one for sale ?
Sometimes a manufacturer will give a different part number to a component because they are fitting it to another model even though the part is identical to a different model . Not sure if this is the case here but maybe .
I'm a fan of the high discharge clutch cover myself. Can't find the part # tho:
nice saw there , bit different to mine , high fliter cover, side exit ehaust , big felling dogs and full wrap :-)
Oh, it has the top exhaust, too ;) That was my felling saw back in Oregon. She's seen a LOT of Douglas Fir.
nice :thumbup: i,m loving mine , did a bit of bucking yesterday on some 24 inch pine and some Elm , rips through it :001_smile:
