That looks very interesting. Do you use your foot as well?
That's the idea, dad was struggling with muscle pain in is arm using the handle all the time so a bit of pressure using the foot pedal helps relieve the arm.
They sound like great mods Billhook but we need pictures :thumbup:
Ok you asked for it!
Guarantee cure for insomnia looking at these pictures, but the mods make a great difference for me as I age.
The first is a load of 8x8 about 15 feet long cut from a massive Ash with the Lucas Mill. It was knotty and verging on rotten in places but the main thing was that I did all the lifting with the teleporter, no splitting or carrying.
I am sorry that I do not seem to be able to load more than one photo at a time from the iphone
This is a frame I welded together with rollers from a boat trailer to take the logs and it makes it easy to slide them sideways to the rollers on the Palax Combi
I fitted a three phase motor and mounted a switch within easy reach for work in the yard. The three point linkage and pro are unaffected and are interchangeable without dismantling for work outside.
I also fitted a drawbar and wheels for towing behind a car
I found knotty and bent branches might fall sideways into the hopper and would jam on the knife after the auto trip triggered the ram so I made a foot pedal (galvanised tube) override. Also I made a T handle to make the removal of the knife easier
Here also is one of the road wheels removed
