Hs81rc clutch drum removal
mitchel
On the RC version the clutch drum and pinion are one unit and need to gently pressed, or drifted out of the bearing after removal of the circlip.
Just be very careful to fully support the casing against the pressures of removal because aluminium will crack quite easily.
The T version by contrast has the drum screwed into the pinion.
I thought this was a safety mechanism on the R version, the brazing shears to protect the rest of the drive train
I didn't realise the T version was different as we only do rough stuff and get through a number of drums on the 30" hs81R
Yes it's an rc what does drifted mean or am I best off taking it to be pressed out
Drifting is basically tapping it out with a hammer and punch (drift).
I would do this before putting it in a press, but either way requires finesse and an instinctive 'feel' By that I mean you hit it hard enough to move it but not so hard as to cause damage.
Support the housing on blocks which spread the load as far as possible and evenly around the gear case. Leave sufficient room underneath for the drum to drop when it is free.
I would use a brass or aluminium drift (punch) to tap the pinion down through the bearing.
Hitting things with a hammer is actually quite a skilled task, but then so is using a press especially a 25 tonne one like mine.
I don't know if its actually designed to shear or whether it just happens that way. Sound feasible though.
