Mowing options
gooseflight
Stability I'm guessing?
Correct Guess:thumbup:
I also have a Kubota B7100 with the wheels set as wide as possible. I have to really plan the way I use it mowing on the steeper parts of the ground I work on and some parts inaccessible with it.
Since purchasing the Goldoni I can work it all without difficulty and feel quite safe across the banks. I have a link box,4 ft flail, frame harrows and Bearcat 5 inch chipper which all work well.
Edited by slim reaper
Thanks, one thing I notice is that the linkage lift capacity on the small alpines seems to be better than the similarly powered Kubotas. Is that correct?
I can only speak from my experience between the B7100 and the Goldoni.
The latter will lift more weight, but not only that I find I dont need front weights where as I require a quite a lot on the former.
