now might be a bit late if the weather stays mild, best time is november. you could do it in stages, do a root trim now, to allow fresh roots to develope closer to the trunk, then lift it in november.
If time allows, I would cut a trench halfway around it as far out as will ultimately be moveable as a rootball and backfill with good topsoil to promote root growth; then move it in November.
Alec
