  • Replies 24
A word of warning, never run the saw with the bar and chain removed, it is very possible for the clutch to un thread on the over run and fly off and can cause serious injury.
As for your problem, make sure the the four bolts up through the crankcase into the cylinder are tight, i have seen these come loose and snap of, this allows the engine to move causing all sorts of issues.
Also not helped if the customer has left the clutch loose and not told you:sneaky2::001_rolleyes:
I agree - they do go quite well when they spin off:blushing:
yeah found that out one day when I fired up a husky 136, the clutch shattered and sent chunks flying in all directions. I think the inboard clutch is a better design for this reason!
