  • Replies 30
LOL! I know a lad who used to have a 60' pulling rope for his landy its now about 20' in two years! he just cuts every time he can't undo his granny knots!:)
pluses: easier to pull tight then timber hitch.
minus: uses more rope, harder to open, can slip if pulled from wrong direction.
To send up to the climber something like a bottle of water or something with a smooth surface and no kink for the rope to hold on to
constrictor knot.
If need be to pull something with the truck? What knot would you use to attach the rope to the truck?
bowline on a blight.
timber hitch
blake loop
or attach a sling to pulling line with a klemheist and about 6 wraps.
What knot to join to ropes together for extra lenght.
overhand bend
water knot
sheet bend
Hi Bill,
I'm curious about the constrictor knot, could you describe it or put a picture on how to tie it...
Thanks
Jack
It would be good to know what type of knots work best and why in different situations. So in a few examples lets see what kind of knot one would use.
Setting up a pulley on a trunk before sectionning down?
Timber hicth its time consuming to set up and pain to keep moving it about specially after loading.
Running bowline its fast to set up easy, to untie even after loading but dont know why dont use it that much in this situation.
Cows hitch never use it, must admit cuase dont know how to tie it. I know that its used for this situation, any plus or minusses???
Lowering down a big section.
Half hitch and running bowline its my choice for the same reasons above.
Half hitch and timber hitch commonly used but time consuming i think.
Any others?
Double bowline perhaps for the same reason!
Its late and running out of ideas! Any other examples?
To secure a load of brush on the back of a trailor?
To send up to the climber something like a bottle of water or something with a smooth surface and no kink for the rope to hold on to.
To make a harness out of a rope?
Any other use that you can think and why?
Good night
Jack-arb
Cows hitch
Bowline
Zepplin
Valdotain tress
