What's the difference in the positioner then if it can be used on flip lines? How easy is it to get on one if the flip line has 2 eyes?
Anyone used the zillion then? I might sell the spiderjack then as like you say it's a same to pull it to pieces
Zillon is ace! Doubles as a secondary mini climbing system if you use it on the longer sizes available, but is still very effective when right up close to the stem. No levers to knock while you are working which is why I was put off the SJ in the first place.
Now you're asking. It can be used for rope covered steel flip lines because of a special cam ( 12-13 mm ) same price as normal cam 11-13 mm. Remove cam and finger lever and fit your line .
Yer I think the zillion will be my next buy as the zz is faultless imo. I felt the same with the sj just seems to be more of a recreational climbing device imo
[ATTACH]196737[/ATTACH]
Sorry that's the first type with many screws.
The newest one has only three to remove.
