Hi just at the end of the day our chipper started using anti stress mode if you understand what I mean. Even 1" diameter stuff gets pulled through like it is 6" big. Any ideas what it could be? Going to try to fix it tomorrow hopefully. Thanks in advance for any help.
Thanks everyone for your help think its sorted now just putting this up for anyone else who ever has this problem. It appears the gap between the sensor and flywheel is wrong should be about the thickness off a pound coin (our jensen is approx 10yrs old has the orange capped sensor). Also the blades if not sharpened at the correct 2 angles or if badly damaged can cause this problem. Once again thanks:)
