Just wondering if any of you know how many cubic metres of firewood logs you will get out of an artic load of unprocessed wood. Thinking of buying a load and im trying to work out my costs.
Bit sceptical of what they are telling me so am looking for a second opinion, its iin their interest to talk up the amount they are selling me after all
Ed is right Vol will depend upon MC and species of timber.
However you can use the FC blue book 39 (Forest Mensuration) to measure the volume of the load prior to it being loaded or estimate the basic density/moisture content and green density using formula therein.
You may also consider the measurement of stacked timber but I assume it’s already on the wagon! This method allows for air pockets within the timber stack but will not allow for MC lost at roadside.
If you require a more precise weight/vol estimation values of coefficient variation should be used.
A cubic meter of timber (species specific) can weigh anywhere between 300kg-100kg . Lets take the mean of those two figures at 650kg - This equates to approximately 1.84 cubic meters. Assuming your timber wagon has a capacity of 25 tons a rough guess would be you can expect 46 Cubic meters of timber. Again this is species specific and depends on the variants listed above. Softwood would be much lighter and thus have a reduced result.
If I was you I would save all the hassle and instruct a timber wagon with weighing facilities then do the basic maths to get a ball park cubic meter figure.
i recon,
26.6t load @ £1000..
1.3t on transit tipper green split logs..
transit tipper = 4 builders bags (0.5m3)..= 2m3
26.6/1.3 =20..
20x2 = 40m3..
so i recon 40m3 is a good guesstemate..
=80 builders bags @ £55 bag =£4400..
so you could quadrouple your money....???
