So after climbing for 18yrs with a rope and Prussik decided it was well overdue a go with a new climbing system.
So I got a zigzag and paired it with the Yale blue tongue.
After one climb on a medium beech tree I'm an absolute convert. Obviously it's not going to be right to use in every climbing scenario we are faced with where as a Prussik can be used for everything but it's a brilliant piece of kit and I definitely recommend them.
  • Replies 44
Well done for making the switch. Are you using a decent cambium saver with pulley for maximum results?
Didn't 1st go thought new rope new territory wasn't sure how fast it would descend. But 2nd tree stuck one up there lovley. So much less effort wish I'd had them all those years.
Enjoy,i climb on a lock jack and i had a go of my friends zigzag (converted) wish i had bought a zigzag now. thanks john.
Cheers John yeah I did contemplate years ago having a brief go on a lock jack but it wasn't for me the zigzags right in the middle spot on. Well done petzl.
Perfect choice of device and rope....welcome to the club! P.s the ZigZag is as versatile if not more than a prussick and is ideal for every scenario. (GREAT in the wet) Pimp your system up with a pulley saver!
Ah but what length of pulleysaver, was going to go for 4m one and daisy chain up when not needed
Go for the small one, I made that mistake, unless you do a lot of big take downs
Got my own one at mo 2.75m and quite often at max length, so thought of longer one or could just add in an extra extension sling when req
Hi did you look at other devices as well ? I'm in the same boat always climbed on prussik and don't know which one to go for ?? But I'm not a regular climber few time a month so I've always stuck with what I know 🤔
