Working well today with the 9010, unlike my 880 POS which refuses to start.
Now will have to try a 3ft bar on the Dolmar
Good idea jim as the saw is , you can use any large husky solo jonsereds bars
With the modified bar studs if you give them half a turn you have the 880 bar mounts you will just have too modify the oiler hole :thumbup::thumbup:
The ps-9010 comes with D033 mounts and a 20" or 24" sprocket nosed bar
The mounts will be changed to D009 mounts as customer requires
Any bar can be supplied in this mount from 20" up to 60"
In the near future there will be 28" and 36" bars available in D033 mounts
Hi Andrew, I'm looking for a new coppicing saw, 35 to 40cc on a 14" Bar, wondered what you had available in that range.
Thanks
Pete
hello Pete
there are three saws in this size range
PS-35C 3/8 lo-pro 35cc
PS-350SC 3/8 lo-pro 35cc
PS-420SC .325 050 42cc
thanks :thumbup::thumbup:
Just quickly Andrew - home owner chainsaw required for cutting firewood. Budget £200-300. What are the options? It's elm mostly, which means more power would be useful (ie, it doesn't need to be a light saw).
J
Hello J
There are three saws in that category
The ps-350sc 35cc semi pro 3/8 lo-pro 12" -14"
The ps-420sc 42cc semi pro. .325 13"-15"
The ps-500c 50cc semi pro , farmers saws 3/8 or .325 15"-18"
These three would be my selection if you didn't want to go down the professional route
But if you wanted too spend a little bit more and want a goood 52cc saw then the 115 would be the one for cutting anything on a 15""- 18" older design but will do everything :thumbup::thumbup:
Cheers
