Hi, I am looking into buying a new Bandsawmill. Possibly second hand. I have never milled before & have searched through this forum and gained quite alot of information. As a overview I own a 15 acre woodland in the UK (Sunny North Yorkshire). I am 1/2 way through my 1st thin & have stacks of Ash & Norweigen Spruce. Generally 6" to 12" diameter with some bigger stuff. I have left the bigger trees standing untill if/when needed. been looking out for second hand mill for ages but none seem to come up at the right location or cost. I am planning on building some buildings next year eg workshop, a few small log challets, plus hopefully building some big 2 storey log cabins however these will be contracted out and timber probably purchased pre cut.
I am working out if its feasable & worth while to do some of the timber myself. I would like to try make my own 3"x2", 4"x2", 4"x4" timber etc plus fence panels, rustic cladding & rustic furnature.
I own a 5ton 360 with grab, tractor, trailers, saws, planers, spindle moulders etc etc however work on my own usually.
I am looking at the Woodland Mills, Hudson, Timbery M100 etc etc. What are peoples innitial thoughts? Thanks in advance.
Bought a Timbery M100 a year ago now. Paid for itself inside 6 months, and would do so even quicker if we had a way of loading the bigger logs. Will do 2' diameter. Not the fastest mill on the market, but does us fine making rustic furniture etc. :)
I'm looking at the 3 phase Norwood HD36, but I want to see how quiet it is first.
I'm hoping I can extend the bed to 11m and that it will take a 800mm ø stem without any punishment.
Edited by Aunt Maud
  • 4 weeks later...
Hi Andy,
I also did a lot of research before buying a mill and did a comparison between the following:-
Hudson 218
Kellfri
Woodland HM126
Holzman BBS550
Dack SM800
Lumag BSW66GL
Trakmet TTP660
All these are entry-level machines and generally in the price range of £2500 to £4000.
Personally, I would buy the Woodland Mills, followed by the Trakmet if you can get a deal on it straight from Poland.
I'm an engineer and looked at most of these and have to say that the Woodland was better built and a bit more sophisticated in things like band tensioning, cam locks for sawhead height etc. It was just better built overall and very well priced at £2600 + vat.
Just my personal opinion, of course.
I have the Trak-met TTS800 standard and it's excellent. Different class of mill but all of Trak-met's products are built like brick outhouses. Mine weighs 4100kg and even the basic TTP600 standard (they do an Eco now which is cheaper) is 1250kg.
I have a lorry coming over from Trak-met later this month with a TTP600 standard and two firewood processors if you wish to see it.
