The uniforest is the only one that will bolt straight on with out an adapter or so I was told by Riko.
Hi Matt,
The Uniforest 35M does fit the AGT835 without any modifications required to the linkage. This is because the PTOs off set as far as it can be allowing plenty of space for the geometry movements.
We do get calls from customers who have purchased an Igland to say that is very tight and we also suggest extending the link arms. You will need the extensions to make enough room but it'll be a great set up once its fitted :001_smile:
As for other manufactures, such as Tajfun and Krpan, we haven't had any feedback so I'm not sure how they compare.
Give me or Stephen a call if you have any questions or if you think we can help,
Calum @ Riko
01420 487300
  • Replies 32
  • 3 weeks later...
Calum @ Riko
Hi, Does the 35M fit a Dexta/MF35/135 linkage unmodified?
Just about to cut the PTO for my Dexta. Looks like the min distance between the UJs will be about 50cm. The offset of the 35M's pto from centreline is about 20cm; that's an angle of about 24degs. I think we're allowed up to 25degs.
I'm wondering if I should rig the winch a bit left of centre with the stabiliser chains, to reduce the offset in the working position? But that would put an angle in the top link which might not be a good thing?
TIA:001_smile:
