New chain saw
Tomeaston
  • Replies 22
Aw right sweet okay cheers. if I was to grind the transfer ports how do I go about this? Cheers
You'd need to change the cylinder to run larger than 28" on a ported 365 special, as the transfers are what is known as open. A quick change to the 372xp cylinder would allow 28" stock, ported it would pull much happier, whilst you could get the 'big bore' kit, ramping the saw up to 75cc, which, once ported would pull 32" like a train.
You can find much information on here about porting, check 'spuds tuning and porting' thread, whilst arboristsite (American version of arbtalk) contains many detailed threads on this saw and its potential port work
