Stump grinder as a JCB attachment
ReubenHayes
We are looking at possible solutions for stump grinding. We can get our hands on a mini digger/JCB and wondered if any other people had used these types of stump grinders. We are thinking of maybe the Cardley-bingham which has either a 260mm, 530mm or 800mm.
Interested to hear if people have used these types of grinders, the problems or benefits they had, are they cost effective or useful?
  • Replies 20
Cheers about the flow, they did mention flow so will check that as well. Do you know if they are easier to use or grind faster? The operator is a bit heavy on normal stump grinders and we do go through teeth.
The speed it will grind at is logically a function of the power available, however, more power wont make him a different operator but it may make damaging things a lot quicker!.
