Looking to get a setup for once i pass my cs38/39, so far I have
Petzl zigzag MK3
Petzl zillon
Petzl Sequoia
Throwline and ball
Ali gecko spikes
What size(mm) and brand rope should I get, Length between 30-40m.
What do you guy's use for carrying your saw? (was thinking a 50cm eye 2 eye)
Opinions on the best carabiners? at least 1 will be a Petzl OK Tract for the zigzag.
Thanks. :biggrin:
Edited by Ragdoll
you want a 11mm rope so that it feeds through the zigzag freely!
Yale blue tongue is a popular choice!
ian
Pretty sure that Petzl recommend 11.5 as their minimum rope diameter.
Petzl zigzag MK3
Petzl zillon
Petzl Sequoia
Throwline and ball
Ali gecko spikes
Thanks. :biggrin:
Couple of things,why not use an endless sling as a chainsaw strop,very little cost and has a multitude of uses.Lots of options for krabs,dmm do lots of sizes,types etc i like the ovals but its a personal choice.
I really dont understand why anyone would get a zillion when you can set up your own lanyard for half the price.Mk3 zigzags are the bollocks but id consider a cambium saver to run your rope through aswell.Safe climbing
Spot on! although you can run 11mm through the zigzag.
I personally wouldnt recommend it,if you take a fall,insurance wont cover you.Just something to consider
I can see an endless sling being a right pita for a saw strop. Twice the amount of fabric to get caught/hung up on stuff. Hitch cord is probably the cheapest idea, but when a bungee strop with a tearaways costs just over a tenner and should last ages (unless you cut it) why bother skimping. Also if using a tape sling on a rear handle saw the weak point becomes the saw, making for a very expensive snatch (no giggling, at the back).
Agreed on the zillion, cheap and easy to buy a micro pulley and some hitch cord. I use a positioner now (which I scorned in the past for being an expensive trinket) and wouldn't move back, but I climbed for years on a hitch.
Like Darrin, I find the petzl oval krabs to be pretty tough, but it's whatever shape and size suits you and your kit really.
