Is it still correct one can fell up to five cubic metres in a calender quarter in the following sizes even when the site has a TPO without needing a FC felling licence?
Diameters at 1.3M from ground levels:-
8cm Individual Stems
10cm Thinnings
15cm Coppice
Purpose is to improve woodland on a clean Brownfield Site.
Thanks
Yes, those exemptions still apply, although you can only sell 2cu out of the 5.
You'll either need a TPO permission to carry out the work, or an FC approved management plan, which will take care of this for you. I guess you haven't got a management plan as this would come with a felling license.
10cm Thinnings
15cm Coppice
Thanks
As 'crobinson' points out, the fact the "less than 5m3" gives you an exemption from the felling licence requirement it doesn't give a TPO exemption...as far as I'm aware, so you'll still need to apply to the LPA to undertake the works.
Tread carefully...:001_cool:
Cheers..
Paul
  • 2 months later...
