There is no great mystery to it.
Your kit will pass or fail on condition and or age.
LOLER expects you to perform pre use checks so there ought to be no real surprises.
Make sure any mechanisms are clean and function as they should, its easy for just a bit of crud to stop a biner working properly. I flush them out with WD40 or similar, dry then and lube with graphite powder.
Make sure your ID's are legible, you can re label stuff as needed but remember to keep track of its date into service, particularly for fabrics.
Don't bother tipping the sawdust out, its not subject to LOLER :laugh1::laugh1:
Make sure you send in all the records in of first use it makes the job easier, an easier job is a happy examiner which is a good thing, I've sent kits back untested for no paperwork and no I'd markings!
