got a siezed one in the shed, carb boot leaking, but other than that complete, let me know if you need parts or want the whole saw as a donor saw. it'll be cheap!
good luck!
  • Replies 34
Not very likly to have been run with no filter as you would never start the thing due to the filter/choke system, do not give up on it, it is well worth spending a bit of money on,i can sort you out a parts list if you wish.
That would be very helpful thank you, I'm not going to give up just yet. The only others I've seen as running are £150 so I guess even if I put £100 into it im still doing ok
Rob
good luck!
Great offer 👍 so far I'm needing air filter but how much would you want for the whole saw? I would just need to sort out getting then
can post it for about £13, dead saw (easy fix actually!) £40? no bar and chain
That sound good to me at least I should have everything to make one good saw that will last a few yrs.
Does anybody know if the parts from the black top model will fit on the white top model that I have?? I'm struggling to get parts & a member has offered to sell me a black top model for parts
Rob
Just been to my local machinery shop who advised the black top & white top are not interchangeable
So now I'm undecided about what to do as I don't fancy ending up with 2 saws that don't work :(
I can't say for certain, but I'm pretty sure they are. I'd suggest getting hold of copies of the IPL for standard 50 and 50 rancher and start comparing part numbers.
I have got a couple of these myself and would offer to help you out with bits, but I'm intending to make one good one from the two myself, so I don't know what bits will be spare.
Go to AS and ask in the beg for manuals thread, you'll soon get sorted on the IPLs, and a workshop manual if you need one.
