Anyone have any ideas?
I've calculated the volumes of a load of sticks and was wondering how I could estimate their weight.
per stick or as a load.
I've found a site that says Ash goes 650kgs per metre cube (seasoned)
I was looking at a load of semi-seasoned sweet chestnut.
Bob
  • Replies 20
Thanks for that.
I had made a few calculations based on 650kg.
I just don't want to under do it too much or I'll not be able to handle it.
Thanks
Bob
could you not use their weight given by kiln dried timber charts?
for instance, european ash is about 680kg for 1 cubic meter at 12%. if you are working in feet then it's 35.31ft3.
wet wood is going to be about 25-30% more in weight.
Seasoned ash is more like 400/450 kg per cube of sub20%
Seasoned sweet chestnut would be quite high I would say around 650/700 kg per cube of sub 20%
seasoned sw chestnut is around 590kg m3.
Bob
Just test a sample.
Cut a piece say 10cmx10cmx10cm. Weigh it then multiply by 1000
When you semi seasoned sweet chestnut how long has it been down? Our experience is it's implausibly slow drying in the round. I have some 3+ years old stuff here so may test some out of interest.
Edited by Woodworks
there will always be differences and to be honest i'm only quoting what's in the books rather than my own measurements.
where abouts in the tree did they come from? remember wood from the top can weigh alot less than the wood at the base.
