We run a RUF600 giving around 500-550kg/hr,started with a 2" flywheel bavaria piston press, but our RUF will press upto 2" dry chip, we grind alot of pallets also and press them thru, it'll even press the nails too!
  • 5 months later...
Is it possible to utilize wood chip to make briquettes? Apart from an actual machine to make them do standard wood chippings made by say a 6 inch arborist chipper need further refinement?
Cheers!
