husky v stihl on raw power only!
Mark_Skyland
  • Replies 45
How much more power in % terms does porting give a saw? Is there any difference in fuel consuption as a result.
I don't normally get a chance to get too much time testing on what I do but recently I ported a 372XP which was already wearing a jungle muffler - that is an empty can, a bit like a big 346XP muffler with an enlarged outlet hole.
The owner was good enough to test the saw pre porting and then we tested it afterwards. The 372 is one of the best saws to port and on the first cuts with it tached to near maximum standard rpms, we got an average improvement of 20% but noted the saw loading up toward the end of the cut. We leaned the saw to 14,000rpm max (500 rpm above standard) and got a further 10% improvement so a total of 30% improvement in cut speed JUST from porting ONLY. The muffler AND porting would give much more.
Difference in fuel consumption - you will have to ask the guys that run these saws regularly!
