I'm trying to decide on how much extra wood I need add to my board when millig so I have enough to plane away.
So if I need to end up with a 1" board what thickness do you cut it in fra the stock? and do you just ad the same amount if it was a 3" og 4" board you need after it is planned?
Jesper
Think 1/4" over would be to little unless very stable wood. The boards are going to shrink in thickness during drying and then there is any cupping and warping to plane out. If you're looking at wide boards planing out cupping can end up with an alarming amount of wood being removed.
Many other variables to consider
The cut of the board ie through and through of quarter sawn
Width you want the finished boards
How perfect you need both faces
How stable the species is
If I needed a perfect 1" finished I would buy 1 1/2" boards and except a fair amount of waste unless I found some exceptional 1 1/4" stock. Somewhere between the two would probably be fine.
If you're just cutting for yourself then it also depends how you're planning on planing the timber later. I tend to rip mine into 26cm widths since that's what I can plane on my planer thicknesser if I had a wider planer then I'd find I was losing more thickness from cupping
