is this possible?? had the rigging rope running through pulleys but it ended up glazed either when doing some normal rigging or when we tagged bits sideways with the tracked chipper whilst lowering them on the portawrap, so is this normal and what was i doing wrong, too bigger bits??? not had any glazing much before.
thanks carl
Edited by carlos
rope was 13/14mm and not sure of the make of portawrap, has got about 3 or 4 inch tube on it if that makes sense. weight of bits.. erm never been that up on weights the heaviest was a large pine limb with a end diameter of about a foot, not crazy big, but pretty heavy.
thanks carl
just googled the portawrap and its rated for 1000kg , so fairly sure we didnt exeed that.
would a larger diameter rope reduce the chances of glaze from the portawrap???
thanks carl
  • 2 months later...
Forgive me if I'm being predantic? but have you done a cs41? You can gain a good basic understanding of various rigging techniques and the different weights, forces, factors, fit for purpose equipment to use for every rigging operation. Sorry again if I've made an assumption
You don't need Cs41 to be competent at rigging, in the same way that having cs39 doesn't make you a decent climber.
I got sent on my 41 a while back as a formality. I learnt virtually nothing I hadn't already figured out with experience or common sense.
