Which chainsaw
doddie82
After much deliberation I went with 362 c-m and I'm pretty impressed with it.
18 inch bar,which I replaced with a sugi hara 18.
I was a bit rough at tick over at the start and stalled a few times,so I did the mtronic set up and run it on aspen fuel.
It's had 6 tanks through it now and running sweet as a nut.
Very powerful,for a 60 cc saw.
I like the captive bar nuts,great air filter system,stainless muffler,mtronic carb,newly designed tool less oil and filler caps.
I turned the oil pump up to maximum as I read it could be a bit frugal,but with an 18 inch bar it's throwing loads of oil out,think I'll put it back to the E setting.
I've only had a couple of Stihl saws before,which was a wood boss and a 039
( which I don't seen to have a photo of)
9C03E71C-6B12-4FD8-876E-0D42CEA3BC03.jpgn
