hi ihave a 350 and is a fantastic machine only one problem you cant sell the firewood fast enough 2 people can produce 50 ton sacks a day average 7 to 8 inch material I have put 700 tons through my machine no problems at all they will make a machine 50percent faster but only so much you can sell but the 350 looked after will last for years cheers philip:thumbup1:
  • 1 month later...
  • Replies 23
Hi PHILP 50ton per day 8" cord how many HRS is the pro running then mate thanks Jon
Here we go Jon:
Tractor at 480 rpm.
At best a 360 will produce 35m3 / 10 hours with Softwood 2 men.
I man/machine loading, taking away, crosscutting/splitting oversize.
Hardwood can take double or 2 1/2 times that time on an average load of Woodland thinnings.
Processing bars and you will definately not sell the amount it will process. :thumbup1:
I don't like like chunky great logs that over 300mm diameter roundwood produces, so avoid processing over that.
Here we go Jon:
Tractor at 480 rpm.
Hi ARB we do not sell SOFT WOOD HERE thanks so what will 350)360 pro with a log deck one man and a loader tractor on 250)300mm cord and logs cut to 10)12 " thanks Jon
Woodland thinnings, hardwood 250 - 300 mm, no oversize, 1 man on his own including handling and maintenance - 4m3 / hr once proficient :001_smile:
some close ups for you guys.
My dad was diagnosed with polymyalgia (pain in many muscles)
so adapting the handle has worked wonders for him and makes the farmi a pretty fast machine to use.
