Hi all my green mech has been playing up she will rev up for about 5 min the die I'd start it up again and it will die I've new diesel flitter and bled it all throw thought would sort it but hasent thought it was to hot but it's not that anymore ideas on wat it could be thanks it's a 325 chip master old machine but a good one any help would be much thanked
Thanks were would that be located
It will be next to the fuel pump with some wires coming out of it, give Pete B a shout he's the gm boffin.
The fuel pump on a CM152 is an old fashioned style lift pump with two valves between the two halves. Not uncommon to get a piece of crud stuck in a valve stopping it from sealing properly. Strip it an clean it it, remove the tank and give that a right good swill too.
I am mentioned the fuel shut off solenoid which is on the same side as the pump but at the front of the engine, near where the throttle cable goes to. If it is okay, the should be a resounding click off of it when you press the oil pressure override button when you first go to start her up.
Thanks for the mention in despatches Ian, yes, I know I am an old bugger who has been around them for a few years!
