Hmmm not sure how to sort this out. Bolt has sheared off leaving the end in the drive shaft but using an easy out will only push it further in as left hand thread.
How can I get the broken bit out?
Thanks
  • Replies 22
Do you reckon the other end is tight in there, or is it just a case of getting to it to make it turn? If you can centre drill it then banging in a long Torx driver can give you something turn. This is easier than a hex bar (Allen key).
Alec
Not tried drilling yet as don't want push in further but may well give that a go :thumbup1:
The bolt is normally quite loose fit in the thread
Ultimately, does it matter if it goes further in, so long as it is free turning and will come back out just as easily? If you can bottom it out then it will give you something to stop it turning, but actually if you can get a drill to it and push fairly hard then it may well be enough to stop it turning anyway. If it's fairly loose then you won't need a very big hole.
Alec
Thanks
You sure its a left hand thread hence why its sheared of ?
What make of mower ?
Ste
OK fess up time.
It's not a left hand thread. Got into my head is was but soon realised otherwise when it went in when drilling. Up side is an easy out has done the trick.
CJ yep the flange does pull off. Had the machine 6 years and never discovered this.
Putting it down to being a chilled Sunday and hope my brain engages again tomorrow.
As for the reason for it sheering I really dont know. It was just doing some basic lawn cutting but it has been known for it to get abused when a brush cutter would be more appropriate.
Anyway Job done with no more damage. Thanks :thumbup1:
Edited by Woodworks
