Anyone using this mower?
Could be an addition to the flock...
Hydrostatic, 80litre sac Magnesium alloy lined with plastic body, Kawasaki engine with oil filter.
2k euros
Ty
Wait for the gear drive one to come out. The GS is about £1300 but the hydro (YS?) is about £1700 and I've read some user reviews that the YS is painfully slow, but the GS has the same gearbox as the 755 which wasn't too slow.
  • 3 months later...
  • Replies 29
anyone having any issues with their Viking mb4rtp? went to cut my lawn today started cutting fine but after about 3minutes it developed one hell of a clanging noise from the deck area.
Guss109, do you have the Toro Timemaster or the Turfmaster? From what ive seen the Timemaster is a domestic machine and the Turfmaster is the professional machine, with a large price diffrence! Diffrent engines too, with the Timemaster having a smaller Briggs. How do you find its cutting and collecting in wet? Does the Briggs engine have enough power to move that 60kg and cut at the same time? Really intrested in these at the moment with the 30 inch cut.
It has side discharge doesn't it? So the blades spin with each other instead of against and it passes all the grass onto one blade before then shooting it into the box. Would be good to have a UK spec that has contra rotating blades and no SD
I have the cheaper one as said it's not keen on soaking wet grass but it fairly beasts on in the dry and packs the box really well. Not to sure if the more expensive one would work any better but I couldn't justify another £400 at the time
