What engine oil should my 2009 tw 190 be using? the manual says refer to engine hand book which i dont have!
The engine manual will probably be available online.
according to the book its
sae10w-30 or
sae15w-40
the engine is a kubota v1505-e so you can check on line
if that helps
it may say what oil on the engine,
sae10w-30 or
sae15w-40
if that helps
Please don't put 10W30 in that engine...:001_rolleyes:
CI specific 15W40 please.
i got that out of the kabota manual,:confused1:
I know; idiots who write manuals in accordance with dumbass short-term environmental policy. Apparently a knackered engine is less net damage to the environment than 0.000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001 extra litres fuel saved over the lifetime of the lump.
:banghead::banghead::banghead:
