I run a 2008 nkr with 55k on the clock,bloody good truck and easy to work on with the tilt cab, been v reliable and isuzu engines are strong,ride quality is crap compared to a van but turning circle is amazing,as a working truck there bloody good.
Pros/cons compared to a Tranny Ian?
Isuzu has higher towing capacity, better turning circle, is built more like a lorry. Downside more expensive on parts and harder to find mechanics that can fault find etc
Transit has bigger load bed, much more comfortable for the driver and passengers. Parts a lot cheaper and more readily worked on.
theres just no way i would consider buying a ford commercial... we have a mwb transit and a transit connect at work and the repair bills are just eye watering! constant problems, worst build quality ive ever seen, and engines and clutches like cheese! was hoping the isuzus are better, would you say there more reliable than transits but when something rarley goes wrong the parts are more expencive? or is your isuzu allways getting fixed?
Never had a tranny mark but also run a relay. Here goes.
Pros
Strong chassis
Strong 3lt engine
Good engine access with tilt cab
Pull well with low gearing
Built as a 5t but down plated for UK.
Amazing turning circle
Looks like a truck not a van
Can tow 3.5t
Cons
Rough ride compared to a van
Low geared so not fast
Bit thirsty
Parts are expensive but parts are generally much bigger than a van
Bouncy when empty
Seats and plastic are a bit naf
Basic compared to a van
Notch gearbox that is layed out different to anything else
Agricultural compared to a van
Edited by Ian C
I'd say at the age and mileage you're looking at your going to have problems with either and the transit will be a lot cheaper to fix. Depends if you get a good one or bad one though.
is there any diffrence in price for mot for these isuzus or is it standard £50? What sort of mpg should i expect from one of these? im guessing that there quite heavy with the tail lift, i was thinking there probily around 2500kg unladen?
