Ash stump regrowth
I have an ash stump almost 3 ft diameter on a hedge that I intend to re-lay. It was done well over 20 years ago judging by 12 to 14 inch stems from the horizontals so I would like to cut it really tight, start again and lay the regrowth.
My question is- Will this ash survive being cut to around 12 inches above its roots. I know its almost impossible to kill smaller ash but do you think there will there be a problem with this size and age.
The worst that can happen is that you coppice it and it doesn't come back. You can't lay it as it is, so you might as well give it a go!
I might even plant a few saplings on the hedge beside it when I cut. That way they would have a head start should the worse happen and would work in for laying anyway. Should be load of nice logs as well. Thanks guys
