That looks like it'll be worth a go. £5 or £6 each off the net, and are described as power transmission belts, and not regular fan belts, so ought to work. Certainly cheaper than from greenmech. May order a pair and see how it goes. Anyone else used them?
I still have a pair hanging up in the workshop...
As I recall, silly money is often asked for these belts, 30euros each from a dealer OR...7euros from the importer near Redon South Brittany.
Ty
So how do you get them tight enough but make sure they are not too tight?:001_unsure::001_unsure::001_unsure::001_unsure::001_unsure::001_unsure::001_unsure:
As a general rule you should be able to twist them 90 degrees or approx 10-15mm deflection between the two pulleys. That's how I did mine today.
On the same song sheet! I said 5-8mm in and out, mid span on the longest run!
Is that in your yard Dean? I had someone after a used one this week.
Sorry Pete, sold before I picked it up, not sure it's because it's a good machine or I am good at my job or both lol.
