New pickups for 2015/16
Steve Bullman
  • Replies 121
A fault I knew was there and put off doing like I said in that post, lack of maintenance, my fault.
Tut tut dean! I had an early 90 years ago and the gear stick came right off in my hand on the A1 :sly: was a good old bus though apart from it leaked oil from just about every orafice!
I can't believe how negative everyone is on this thread, by all accounts all the pick ups are crap unles it's a land cruiser and I ain't ever seen a tipper one over here. I love my landrover 130 crew cab tipper to bits!! Perfect for me and I don't have any complaints. It earns me plenty of money and doesn't cost me that much to run. It tows 3.5 tonne, carry about 5 cube of chip and carets all my gear and looks ace!! I won't put a picture up as it will only wind mountain man up:)
It could be that most people's first experience of a defender is the 200,000 mile ex utility wreck which stays with them for years. A new jap motor changed every 3 years is unlikely to give much grief but if you use it hard it will cost you when you blow a gear box or bend a prop. Personally at 6 ft 3 I would not want to go far in a defender. For towing you really can't beat an Amazon it has the weight the stability and the cc's and will do 250 k before it gives a major component problem.
But can you get it in a crew cab tipper? I'm 6ft 1 and have a crew cab, small steering wheel heel and seat extenders. It's fine. Each to their own but if it won't tip then it no good to me:)
I've got 4 landys and they serve me well, full service every 6 months and keep on top of the little bits and they give little trouble, just had a clutch fitted in my oldest one, a 99 td5 with 175k on the clock, first time I've had to spend anything on it other than little bits for mot
Ha ha! Nearly missed that, that Land Rover holds more chip every week! Is it growing?
